nikoweb
Dec 13, 2014Aspirant
OSX Maveric and RN 516 - smb problem #25261052
Hello, I have a RN 516, with firmware 6.1.9, but access from Mac OSC10.10 with smb is slow. is slow to show the folder, and copy files, also some folders do not give access privileges due (I also trie...
Dec 13, 2014Guru - Experienced User
Teaming (what you are calling "NAS BOND") can improve performance when you have multiple users, but it will not improve performance if you only have a single user. Basically it only helps if the network connection between the NAS and the switch is the bottleneck. In many cases it isn't.
Did you try AFP?
It also sounds like you need to reset permissions in some of the shares. If you are using the default share permissions, there is a "reset" button in frontview you can use. Otherwise you might need to use ssh. The reset button is on the "file access" tab in the share settings.
Did you try AFP?
