nikoweb
Dec 13, 2014Aspirant
OSX Maveric and RN 516 - smb problem #25261052
Hello, I have a RN 516, with firmware 6.1.9, but access from Mac OSC10.10 with smb is slow. is slow to show the folder, and copy files, also some folders do not give access privileges due (I also trie...
mdgm-ntgr
Dec 19, 2014NETGEAR Employee Retired
The NICs are auto-sensing on all ReadyNAS. There has never been a need to use a crossover cable for direct connections though of course you can if you want to.
You may also wish to try 6.2.1
Perhaps also send in your logs (see the Sending Logs link in my sig).
