nikoweb
Dec 13, 2014Aspirant
OSX Maveric and RN 516 - smb problem #25261052
Hello, I have a RN 516, with firmware 6.1.9, but access from Mac OSC10.10 with smb is slow. is slow to show the folder, and copy files, also some folders do not give access privileges due (I also trie...
RX
Dec 29, 2014Luminary
nikoweb wrote: Thank You.
I tried to update to 6.2.2, but the problems do not change. Always slow connection from Maverick 10:10 and snow leopard 10.6.8. Windows XP is fine. I also tried to connect the NAS directly excluding the HUB but always goes slow. The volumes are 6 x 4 Gb in Raid 10.
Since the connection from the Windows XP computer is still fine, are there any possible updates that could be done on the software driver of the ethernet adapter on the Maverick and Snow Leopard MACs?
