rajamani_v
Jun 25, 2019Aspirant
Overheating of ReadyNas RN104 power adapter
Hi, I have been using ReadyNAS 104 for more than 4 years now. Of late, the power adapter gets over hot and the unit shuts down automatically. If switched on after a while, it works perfectly, but...
Jun 26, 2019Guru - Experienced User
Retired_Member wrote:(1) Do not expose the power adapter to direct sunlight.
Where did this one come from? AFAIK there is no harm in putting an AC power adapter in the sun. Though you will see advice not to put lithium batteries in direct sunlight.
rajamani_v : What firmware are you running? Is your NAS still under warranty (3 years for the original purchaser)?
Your system should be using about 30 watts of power in normal operation (based on the normal power use of your specific drives + 9 watts for the NAS chassis). The RN104 adapter should be able to provide about 45 watts, so there should be enough margin to handle spinup, etc.
Are you certain that the thermal shutdown is caused by the power adapter? It is possible that that NAS itself is overheating (and drawing enough power to heat up the adapter). Try downloading the log zip file, and see if you can find any clues related to the shutdown events. You can also send a private message (click on the envelope icon on the upper right of the forum) to one of the mods ( JohnCM_S or Marc_V ) and ask them to analyze your log zip. Put the zip into cloud storage (e.g. ,google drive, dropbox, etc), and include the link in the PM. Don't post it here.
You could also try monitoring the NAS temperatures on the performance tab of the web ui, and make sure that the disk and CPU temps aren't climbing too high. It might also be useful to pull out the drives shortly after the thermal shutdown, and see if one is particularly hot. (Put them back in before powering up the NAS).
If the power adapter itself is overheating/failing (but the NAS chassis is not), then you can replace the adapter.
rajamani_v
Jun 26, 2019Aspirant
Hi, attached is the screenshot of the CPU's temperature when the fan setting was "Quiet",changed it to "Cool" then the temperature dropped.
Had a thermal shutdown after having the NAS working for close to an hour. Checked the harddisks, none of them were hot, they were lukewarm, nothing noteworthy.
- StephenBJun 27, 2019Guru - Experienced User
rajamani_v wrote:
It has been more than 4 years, so am assuming it will not be under warranty.
Yes, it is out of warranty
rajamani_v wrote:
6.10.1 is the firmware in the system
Thx. There was an issue with the NIC in the NAS overheating and shutting down. But Netgear made a driver change, so 6.10.1 shouldn't have that problem. Plus no one reported an overheated power adapter.
The disk temps look ok to me too.
The NAS log says that it is doing a thermal shutdown? Or did it abruptly shut down, or give some other reason?
The NAS can't monitor the adapter temp. So if the adapter is at fault, then I'd either expect the NAS to shut down abruptly (with no indication of why) or perhaps shut down due to an out-of-spec voltage threshold. Either way, I'd just replace the power adapter.
But if there is a thermal shutdown in the NAS, then that suggests the NAS is drawing too much power from the adapter. That seems unlikely given the temps image you posted, but worth double-checking. Though it might be still possible that the issue is the adapter itself.
Perhaps Sandshark has some thoughts.
- SandsharkJun 27, 2019Sensei
Assuming for a minute that it really was a thermal shut-down of the NAS, it would be hard to dignose which is the symptom and which the cause for a power supply overheating. An overstressed DC=DC converter in the NAS or a partially shorted capacitor could draw too much power or an overstressed external power brick could be delivering insufficient voltage to allow the DC-DC converter to work efficiently.
It's critical to know if it really was an overheat shut-down or perhaps a voltage out of tollerance. But even with that information, it's going to be hard to diagnose without measuring the voltage and current the brick is supplying, and possibly the internal voltages. Just swapping out the brick could be a better step, since few have the equipment for the other. I've seen compatible supplies listed on eBay (12V, 7.5A, 4-pin DIN connector).
- rajamani_vJun 27, 2019Aspirant
Sandshark wrote:Assuming for a minute that it really was a thermal shut-down of the NAS, it would be hard to dignose which is the symptom and which the cause for a power supply overheating. An overstressed DC=DC converter in the NAS or a partially shorted capacitor could draw too much power or an overstressed external power brick could be delivering insufficient voltage to allow the DC-DC converter to work efficiently.
Most of it went over my head :) But understood that external power brick could be delivering insufficient voltage. Will try compatible brick and let you guys know. Anything in particular that you recommend.
Cheers!
StephenB wrote:The NAS log says that it is doing a thermal shutdown? Or did it abruptly shut down, or give some other reason?
The NAS log doesn't have anything related to the shutdown, it abruptly got shutdown.
Think, I mis-understood the term Thermal shutdown as shutdown due to overheating of the Power adapter while it actually is shutdown due to the overheating of harddrives / NAS.
In my case, the NAS & harddrives are absolutely fine. So, will replace the adapter and check.
Thanks for all your help!
