Hewlas
Jul 22, 2018Follower
password reset
I am trying to reset the admin passord vias the boot menu but find I cannot access teh boot menu. Pressing reset while powering doesnt seem to work. Any help would be greatly appreciated\Hewlas
- Jul 23, 2018
Hi Hewlas
You may try the methods on the link provided on recovering lost or forgotten Administrator Password. You can also perform OS-Reinstall but you have to make sure you have the Duo V2. Here is how you can determine the unit.
Recover Password on OS 6- Omitting this since it's for OS 6. OS Reinstall should do with your DuoHope this helps!
Regards
Marc_V
Jul 23, 2018NETGEAR Employee Retired
Hi Hewlas
Recover Password on OS 6 - Omitting this since it's for OS 6. OS Reinstall should do with your Duo
Hope this helps!
Regards
Jul 23, 2018Guru - Experienced User
Marc_V wrote:
... but you have to make sure you have the Duo V2.
I just want to emphasize the importance of this.
A lot of v1 owners mistakenly think they have a v2 - the labeling on the back is misleading. So you need to confirm the platform version before you proceed.
