steveoelliott
Jun 02, 2017Luminary
Performance graphs
Hi all, I am curious as to why I now have no data in my performance graphs irrespective of the period I select. Any ideas??? I had an NTP issue a few days ago which set my clock back to 1st J...
Jun 02, 2017Guru - Experienced User
I think that's just a side effect of the bad time. If you google, you'll see several other reports of this after NTP messes up.
steveoelliott
I know but how do I get my graphs back... I'm thinking deleting the .rrd files will suffice but I'm keen to get feedback.
- SkywalkerJun 02, 2017NETGEAR Expert
You've discovered a bug in the handling of a rewound clock by the thread that updates the graph data. If you don't reboot (or restart readynasd), you won't see any graphs for the next 14 years. :smileyhappy: The underlying issue here will be fixed in 6.7.5.
- steveoelliottJun 03, 2017Luminary
Thanks...
How can I safely restart readynasd on a running system without impact? I have SSH access.
Something else I've noticed too is that following each upgrade the historic data on the graphs is lost too, although this may be intentional.
- SkywalkerJun 05, 2017NETGEAR Expert
You should actually be able to wake up the thread non-destructively by running this command once or twice:
# pgrep -w readynasd | xargs kill -HUP
