gilligan1
Jan 08, 2012Aspirant
Performance problems with my NV+
[Setup / Devices] ReadyNAS NV+ / 1GB RAM (RAIDiator 4.1.9-T2 [1.00a043]) / 4xSeagate ST31000528AS 1TB disks / 0.9 of 2.7TB free FritzBox Wlan 3170 drink green DGS-1005D Gbit switch macbook pro ...
gilligan1
Jan 11, 2012Aspirant
$ dd if=/dev/zero of=test.bin bs=1048576 count=500
500+0 records in
500+0 records out
524288000 bytes transferred in 22.583006 seconds (23216041 bytes/sec)
--> 24216041/1024/1024 = 23MB/sec
So that poses a problem/bottleneck. I will reboot&fsck - which will
probably take forever - and I'm not sure if that will be of much help.
*EDIT*
I checked the Hardware Compatibility list : http://www.readynas.com/?page_id=82
My disks (ST31000528AS) are listed as supported for the NV+
I am a bit confused by what hdparm is reporting about the drives though:
$ hdparm -d /dev/hdc
/dev/hdc:
using_dma = 0 (off)
$ hdparm -i /dev/hdc
DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5 udma6
Cycle time: min=120ns recommended=120ns
PIO: pio0 pio1 pio2 pio3 pio4
So according to this udma5 is selected, but if hdma is to be trusted dma is still
switched off anyway ? Trying to set pio mode or dma on/off yields a "Function not implemented"
500+0 records in
500+0 records out
*EDIT*
/dev/hdc:
using_dma = 0 (off)
