tkggdhqcss
Jul 22, 2021Initiate
please help send newest BIOS for RN51600
Dear All , I have a readynas rn51600 , but it not work after i changed some bios setting , this morning i set a USB disk to boot Rescue tool to fix my defect Hard Disk , maybe set s...
tkggdhqcss
"you’d need to use soldering skills (advanced repair) to remove the BIOS chip and put a replacement one in (no idea where you’d get that) or replace the motherboard "
yes , i checked the MB , the BIOS chipset is WINBOND 25064FVSIG , i want try remove and change the BIOS ROM chipset , i can find the same chipset and a tool to flash it , but need the correct BIOS file , can you help send the BIOS BIN file to me ?
Sandshark
Jul 22, 2021Sensei
I understand that BIOS changes on the OS6 NAS can require other configuration changes in the DMI and elsewhere, and those can be different depending on the old version as well as the new. Because of this, Netgear has not made the updates available publicly, and likely never will.
