KevinP93
Sep 02, 2016Aspirant
Plex Updated and lost my liberys...but
Yesterday my Plex app updated on my ReadyNAS 214, however my library and metadata are no longer there and had to create a new server....but when im in plex choosing a folder i can see in the /app fol...
- Sep 08, 2016
KevinP93 wrote:
I have hidden folders viewable but whenever I do
\\ip of nass\data or further information get network error windows cannot access said path...but when I do \\ip\Videos or other folders they load up nicely, granted I know because they are public folders but for some reason I cannot get the hidden ones to load up.That's probably because you aren't using admin credentials for the NAS. Another possibility is that you are using flexraid, and named the volume something else.
Assuming the volume is called data, then open CMD and enter
net use * /delete
net use t: \\ip-of-nas\data /user:admin nas-admin-password
That should mount "data" as drive letter t.
Sep 03, 2016Guru - Experienced User
KevinP93 wrote:
how do i turn on hidden folders within the NAS so i can copy my data over to the other folder that aperantly Plex decited to make?
First you need to use windows credentials to access the data volume.
From there it helps a little if you enable hidden files from Windows. But you can enter \data\.apps into the address bar and get into the .apps folder.
- mdgm-ntgrSep 03, 2016NETGEAR Employee Retired
The Plex app for the RN214 is the Annapurna build, the one for "ARM 6.x RN2XXX" available at plex.tv/downloads. Is that the one you installed both now and previously?
- KevinP93Sep 04, 2016Aspirant
That is what i used to update, since the plex app was no longer downloadable through the READYNAS app store, and when i was on the plex site i tried to download the other arm 6. one but for some reason my nas system said it couldn't use this app/program/file.
- BrianL2Sep 06, 2016NETGEAR Employee Retired
Hi KevinP93,
Welcome to the community!
Thanks for the information that you provided. Have you tried what StephenB suggested?
Kind regards,
BrianL
NETGEAR Community Team
