KevinP93
Sep 02, 2016Aspirant
Plex Updated and lost my liberys...but
Yesterday my Plex app updated on my ReadyNAS 214, however my library and metadata are no longer there and had to create a new server....but when im in plex choosing a folder i can see in the /app fol...
- Sep 08, 2016
KevinP93 wrote:
I have hidden folders viewable but whenever I do
\\ip of nass\data or further information get network error windows cannot access said path...but when I do \\ip\Videos or other folders they load up nicely, granted I know because they are public folders but for some reason I cannot get the hidden ones to load up.That's probably because you aren't using admin credentials for the NAS. Another possibility is that you are using flexraid, and named the volume something else.
Assuming the volume is called data, then open CMD and enter
net use * /delete
net use t: \\ip-of-nas\data /user:admin nas-admin-password
That should mount "data" as drive letter t.
KevinP93
Sep 08, 2016Aspirant
In CMD I'm able to type in the net path, but then is ask's for the admin password but I'm unable to type anything in for password...all I can do is push enter and it comes up as "system error 86 has occurred... the specified network password is incorrect"
What would hinder me from typing the PW in CMD?
Sep 09, 2016Guru - Experienced User
It sounds like you might be mis-typing the command. The version I gave you has the NAS password on the command line itself.
That is, the actual NAS password should have been entered instead of nas-admin-password
