KevinP93
Sep 02, 2016Aspirant
Plex Updated and lost my liberys...but
Yesterday my Plex app updated on my ReadyNAS 214, however my library and metadata are no longer there and had to create a new server....but when im in plex choosing a folder i can see in the /app fol...
- Sep 08, 2016
KevinP93 wrote:
I have hidden folders viewable but whenever I do
\\ip of nass\data or further information get network error windows cannot access said path...but when I do \\ip\Videos or other folders they load up nicely, granted I know because they are public folders but for some reason I cannot get the hidden ones to load up.That's probably because you aren't using admin credentials for the NAS. Another possibility is that you are using flexraid, and named the volume something else.
Assuming the volume is called data, then open CMD and enter
net use * /delete
net use t: \\ip-of-nas\data /user:admin nas-admin-password
That should mount "data" as drive letter t.
KevinP93
Sep 09, 2016Aspirant
Well after submitting that last post I finally got in. No I didn't have anything mounted on t before or even after...... but for some reason I could now do \ip of nas\data and it finally showed up after doing the CMD walk-through. I'm now in the process of moving my old meta-data over to the new folder now!
Thank you all so much for the help and knowledge given!!
- JennCSep 10, 2016NETGEAR Employee Retired
Hello KevinP93,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
