Vez
Jul 22, 2016Aspirant
Poor read performance - 6.5.0 On Ultra 4 Plus
I upgraded to 6.5.0 a while ago, mainly to get the new plex updates, and have read of a slight performance hit, and I expectedthat. However write performance is exceptional, able to write at 100M...
- Oct 04, 2016
Might have found a solution:
https://community.spiceworks.com/topic/1581799-readynas-516-extremely-slow-nfs-performance
Will test a little later.
Vez
Right I have shut down my VMware cluster and read performance is as expected 100mb via SMB. Previously I was still able to get 100mb through put on my desktop with the VMware cluster running!
So this would indicate to me an issue with NFS? Any help would be welcomed.
- VezJul 22, 2016Aspirant
Right, single VM, 2 NFS threads, and SMB file transfers are ~30mb. Turn the VM off and I get 100Mb again from SMB.
- StephenBJul 22, 2016Guru - Experienced User
Do you have any way to gauge how much I/O the VM is doing?
Its a 2012 domain controller sat there only serving DNS - with zero accounts on so no authentication. I will check the vsphere logs later after spining it up again.
