Weevil1
Mar 14, 2014Aspirant
Poor streaming connection/speed
ReadyNAS NV+ v2 WNDR4500 2 x Powerline AV500 Tvix N1 Network Player Hello. My first post at the ReadyNAS forum (previous Stora owner!). I hope someone can help me; I'm getting really frustra...
Weevil1
Mar 19, 2014Aspirant
Hi,
I have a long CAT6 cable somewhere. I'll connect the tvix to the the router with this - it should almost get into the room it usually inhabits and , together with a long HMDI cable, I can connect the tvix to my AV setup. Although I'll get some earache over the cables everywhere ( :roll: ), this will take the Powerlines out of the equation and enable me to establish that the tvix is actually capable of playing Bluray via the network from the NAS. As mentioned in an earlier post, it will play Bluray files from an attached USB2 drive, so I'm assuming it ought to play OK.
What's the best way of tackling the low throughput from the NAS?
Sorry - I meant that the DVD files are not compressed any further than they already are on the original DVD - they are direct ISO backups.
