Weevil1
Mar 14, 2014Aspirant
Poor streaming connection/speed
ReadyNAS NV+ v2 WNDR4500 2 x Powerline AV500 Tvix N1 Network Player Hello. My first post at the ReadyNAS forum (previous Stora owner!). I hope someone can help me; I'm getting really frustra...
Mar 19, 2014Guru - Experienced User
How are you accessing the file? If you are using SMB, then try NFS. NFS is often more efficient for linux devices (most media player devices use linux), and is supported by your player.
What format is the file in (ISO, m2ts, MKV, ...). If it is not ISO, then perhaps download mediainfo from http://www.videohelp.com/tools/mediainfo, and have it analyze the the file. Select the "text" view, and cut/paste it into a followup post.
