Weevil1
Mar 14, 2014Aspirant
Poor streaming connection/speed
ReadyNAS NV+ v2 WNDR4500 2 x Powerline AV500 Tvix N1 Network Player Hello. My first post at the ReadyNAS forum (previous Stora owner!). I hope someone can help me; I'm getting really frustra...
Weevil1
Mar 20, 2014Aspirant
StephenB... Thanks for the suggestion; the tvix was using SMB, so I changed it to NFS, but I couldn't see any improvement in the file playback. The file is a mkv from a Bluray. Details below;
fastfwd... Sorry about the confusion over my post last night. I posted, then immediately started editing it to get my thoughts into order... you must have replied while I was still editing. Sorry! My thinking (that I 'edited out') was that if the Powerlines were causing a drop of >70% of the NAS speed, then maybe an increase in the NAS speed from the current 25MB/s could lead to a higher speed than the current 6.9 MB/s by the time it's gone through the Powerlines... maybe bringing it up to Bluray capability.
Am I right in thinking I have two issues - 1) the player cannot cope with the throughput needed through its LAN port (although it can via USB2). And 2) even with a player with a capable LAN port, the current drop down to 6.9 MB/s means that the NAS needs to be tweaked (somehow?!) to bring this up? Any other thoughts?
mediainfo.....
UniqueID/String : 223939786542345061800280457564165362706 (0xA8793BEBA0F34068B76A5F43FC45D412)
CompleteName : \\NAS-BE-92-17\media\movie\TV\Firefly\01 - Serenity.mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 15.2 GiB
Duration/String : 1h 26mn
OverallBitRate_Mode/String : Variable
OverallBitRate/String : 25.0 Mbps
Encoded_Date : UTC 2014-03-09 17:24:29
Encoded_Application : libmatroska built on Aug 28 2013 17:28:01
Encoded_Library/String : libebml v1.2.0 + libmatroska v1.1.0
Video
ID/String : 1
Format : AVC
Format/Info : Advanced Video Codec
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 3 frames
CodecID : V_MPEG4/ISO/AVC
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate_Mode/String : Constant
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Language/String : English
Default/String : Yes
Forced/String : No
Audio #1
ID/String : 2
Format : DTS
Format/Info : Digital Theater Systems
Format_Profile : MA / Core
Format_Settings_Mode : 16
Format_Settings_Endianness : Big
CodecID : A_DTS
BitRate/String : Unknown / 1 509 Kbps
Channel(s)/String : 6 channels
ChannelPositions : Front: L C R, Side: L R, LFE
SamplingRate/String : 48.0 KHz
BitDepth/String : 24 bits
Compression_Mode/String : Lossless / Lossy
Video_Delay/String : 1mn 5s
Forced/String : No
Audio #2
ID/String : 3
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
CodecID : A_AC3
BitRate_Mode/String : Constant
BitRate/String : 224 Kbps
Channel(s)_Original/String : 2 channels
ChannelPositions : Front: L R
BitDepth/String : 16 bits
Compression_Mode/String : Lossy
StreamSize/String : 139 MiB (1%)
Forced/String : No
mediainfo.....
Format : Matroska
Video
ID/String : 1
Format : AVC
ColorSpace : YUV
Forced/String : No
Audio #1
ID/String : 2
Format : DTS
CodecID : A_DTS
Forced/String : No
Audio #2
ID/String : 3
Format : AC-3
CodecID : A_AC3
Forced/String : No
