Weevil1
Mar 14, 2014Aspirant
Poor streaming connection/speed
ReadyNAS NV+ v2 WNDR4500 2 x Powerline AV500 Tvix N1 Network Player Hello. My first post at the ReadyNAS forum (previous Stora owner!). I hope someone can help me; I'm getting really frustra...
Mar 22, 2014Guru - Experienced User
The SMART info looks good. Hopefully reallocated sector count, current pending sector, and ATA error rate are 0 on all drives.
There have been some NV+ v2 users who reported reduced performance with >80% disk full. You are at 86% full. So it is possible that you are seeing this. Though 5.3.9 was supposed to include some fixes for that.
The pro and v1 NAS keep stats on ethernet errors. I'm not seeing that in the v2 software guide, but you might look for them. If you have spare ethernet cables, you might try swapping them, and seeing if ethernet performance improve.
As far as settings go, use the defaults with the following adjustments (if needed):
enable flow control
disable interrupt moderation
disable anything with "offload" in the name.
disable jumbo frames.
enable flow control
