powellandy1
May 18, 2016Virtuoso
Possible failed upgrade (Cloud options) with release 6.5.0
Hi I have 3 units. I have upgraded them all to 6.5.0 as prompted. First I migrated my account to myNetgear as described in the email that came round a while ago. Two of them - the Pro6 and Ultra...
- May 18, 2016
For the first issue, can you try clearing your browser cache (or use a private / incognito window).
Regarding the RN102 - are you sure it is not online right now? It should only realise that an update is available if it is actually online.
BrendanM
May 18, 2016NETGEAR Expert
- powellandy1May 18, 2016Virtuoso
Hi
How very amateurish of me! You are right, clearing the cache resolves it.
The RN104 - I'm pretty sure its set to come on a 6pm but I will check tonight when I am next to it.
Thanks
A
Hi
It was on just seemed ReadyCLOUD could never update it remotely.
Did it manually then had to remove and re-add two of the NASes to ReadyCLOUD and now all works as it should :)
ThanksAndy
