powellandy1
May 18, 2016Virtuoso
Possible failed upgrade (Cloud options) with release 6.5.0
Hi I have 3 units. I have upgraded them all to 6.5.0 as prompted. First I migrated my account to myNetgear as described in the email that came round a while ago. Two of them - the Pro6 and Ultra...
- May 18, 2016
For the first issue, can you try clearing your browser cache (or use a private / incognito window).
Regarding the RN102 - are you sure it is not online right now? It should only realise that an update is available if it is actually online.
BrendanM
May 18, 2016NETGEAR Expert
powellandy1
Hi
How very amateurish of me! You are right, clearing the cache resolves it.
The RN104 - I'm pretty sure its set to come on a 6pm but I will check tonight when I am next to it.
Thanks
A
- powellandy1May 18, 2016Virtuoso
Hi
It was on just seemed ReadyCLOUD could never update it remotely.
Did it manually then had to remove and re-add two of the NASes to ReadyCLOUD and now all works as it should :)
ThanksAndy
