michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread...
yoh-dah
Oct 01, 2006Guide
patja wrote: I am seeing some pretty strong results...makes me wonder if I missed something in the Iometer setup instructions, but I've triple checked them. I've done 6 runs now and see:
Writes: 35 or 56 MBps (half the time it is 35, half 56)
Reads: 33, 47, and 72 MBps (of my 6 runs I've got two at each of these)
Everything on the ReadyNAS is setup per the instructions on the forum. I am only sharing as CIFS. No SMB and no HTTP.
The network switch is a SMCGS8
My PC is an ASUS A8N-E, Athlon X2 3800+, 2 GB RAM, onboard gig ethernet (Nvidia)
Do you guys see consistent results from one run to the next?
As much as I'd like to want to believe the ReadyNAS is that fast, I think it might have to do more with caching on the PC side as you have 2GB of memory. If you use a larger test data size with IOMeter, you'll probably get a more consistent result.
