michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread...
simonb681
Nov 02, 2006Aspirant
ReadyNAS NV Rev B
2 x HGST 7K250 250GB HDDs
Firmware: RAIDiator™ v3.00c1-p2 [1.00a025]
Memory: 256 MB [2.5-3-3-7]
Online, 95% of 227 GB used - X-RAID (Expandable RAID), 2 disks
Access: CIFS, FTP, HTTPS
Performance: Enable Write Cache, Disable Full Journaling, Enable Fast Writes
PC
Intel D875PBX
Pentium 4 Northwood 3.0 GHz HT
2 x 1GB DDR RAM Dual Channel 2-3-3-6
NIC
Intel PRO/1000 CT
Auto Neg 1000 Mbps
Default Settings
Intel PROSet 11.1.0.19
Switch
NetGear GS105
Cat5e cables
Results
NV Jumbo On, Direct, NIC @16k
256K_Write 20.589032
256K_Read 20.875454
NV Jumbo On, Direct, NIC @9k
256K_Write 20.501461
256K_Read 20.939234
NV Jumbo On, Direct, NIC @4k
256K_Write 15.570781
256K_Read 20.919339
NV Jumbo On, Direct, NIC JF Disabled
256K_Write 7.799292
256K_Read 21.535115
NV Jumbo Off, Direct, NIC JF Disabled
256K_Write 14.291266
256K_Read 24.301739
NV Jumbo Off, via Switch
256K_Write 15.708299
256K_Read 24.55822
NV Jumbo On, via Switch, NIC @9k
256K_Write 20.244404
256K_Read 20.87902
These seem to be consistent with others in that enabling JF helps writes but slows reads. The interesting result is 'NV Jumbo On, via Switch, NIC @9k' which considering the switch is not supposed to support JF gives the same results as direct. Furthermore I can surf the net just as quickly it seems via my 100BaseT Draytek ADSL router. Since I have done the majority of the copying to the NV I think I will stick with JF off for the improved read, but it might be worthwhile enabling JF as and when I need to do any more bulk copying.
I have two HGST T7K250 250GB HDDs on order to bring the RAID upto 1TB, as well as 1GB stick of Patriot RAM, so I'll post back with updated performance tests once these are installed.
PC
Intel D875PBX
NIC
Intel PRO/1000 CT
Auto Neg 1000 Mbps
Default Settings
Switch
NetGear GS105
Cat5e cables
Results
256K_Read 20.875454
256K_Read 20.939234
256K_Read 20.919339
256K_Write 7.799292
256K_Read 21.535115
256K_Read 24.301739
256K_Read 24.55822
256K_Read 20.87902
