michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread...
edmebba
Nov 14, 2006Aspirant
edmebba wrote: PC:
Dell XPS 400
CPU Pentium D 2.80Ghz
Memory 3.25G
Network Equipment:
Dlink DGS-1008D* ( 10/100/1000 No JF support? The D-Link user manual says otherwise but it's on the Infrant HDW Incompatibility list. )
* Will post results after getting a D-Link DGS-1005D that supports JF.
Network Topology:
Dell ------ D-Link------Infrant
Intranet-----|
NAS Configuration:
Infrant ReadyNAS NV+
Version: RAIDiator v3.01c1-p2 [1.00a032]
Memory: 256MB [2.5-3-3-7]
RAID
X-RAID Redundant
Disk Write Cache enabled
Full Data Journaling Disabled
Fast CIFS writes Enabled
Disks
4-500GB Hitachi "Deathstars" ( HDS725050KLA360 )
Results:
1000Mbit JF Off
Sectors: 2048000
Write MBps: 15.670103
Write Iops: 62.680412
Read MBps: 28.604001
Read Iops: 114.416004
Sectors: 8192000
Write MBps: 15.180526
Write Iops: 60.722104
Read MBps: 28.140746
Read Iops: 112.562983
1000Mbit JF On
Sectors: 2048000
Write MBps: 7.444973
Write Iops: 29.779891
Read MBps: 23.555285
Read Iops: 94.22114
Sectors: 8192000
Write MBps: 7.320481
Write Iops: 29.281924
Read MBps: 24.238073
Read Iops: 96.952293
Thanks
EDM
Got the D-Link DGS-1005D and got the same numbers, any sugestions? I do not see a direct way to set host system to use Jumbo frames, according to the Users guide I just need to make sure the Intel Pro Set utility is being used, which it is. The Intel host system card is a Intel Pro/1000 PL. The host system that is running Iometer and the Ready NAS are plugged directly into the D-Link DGS-1005.
EDM
