michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread...
NeilPeart
Mar 31, 2008Aspirant
Dinger928 wrote: Well, not sure how to interpret these numbers. Perhaps someone could help me out a little? I'm sort of suprised that with jumbo frames turned on that the read performance really didn't increase at all. Seems like it did with the write performace though. Seems almost symmetrical. Is that ok? Good, bad or indifferent?
From this thread: http://www.readynas.com/forum/viewtopic.php?f=17&t=17433&start=0
yoh-dah wrote: Keep in mind that jumbo frames works only one way with the ReadyNAS -- when you're writing TO the ReadyNAS.
For reference here are my Iometer results:
ReadyNAS NV+ [X-RAID]
RAIDiator 4.01c1-p1 [1.00a041]
1024 MB [ 2.0-2-2-6 ]
4x WD4000YR
All NV performance settings enabled
Factory-reset for 16K blocks
SMC SMCGS8 GigE switch (9K Jumbo Frames)
Windows XP Professional SP2
AthlonXP 2500+ @ 2.30GHz
1GB PC3200 @ 2-2-2-8
3Com 3C996-T (PCI Server NIC)
-Tx/Rx Checksum Offload Disabled (improved read results by 3 MBps, but increased CPU utilization by 2.5%)
-Flow Control Auto
-Jumbo Frames Enabled (9000 MTU max)
Read: 33.792488 MBps
Write: 37.975341 MBps
Windows Vista Ultimate 32-bit SP1 (yes I will install the 64-bit version when I have time to reformat one day)
Core2Quad Q6600 @ 3.01GHz
4GB PC6400 @ 4-4-4-12
Realtek RTL8169 (On-board NIC)
-Tx/Rx Checksum Offload Disabled (improved read and write results by 4 MBps, and CPU utilization only increased by .5%)
-Flow Control Enabled
-Jumbo Frames Enabled (7000 MTU max)
-Large Send Offload Disabled (disabling this was key to improving read results by nearly 20 MBps)
Read: 34.76672 MBps
Write: 41.185671 MBps
