michelkenny
Sep 25, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread for easy comparison.
You can run IO Meter by following the steps here: http://www.infrant.com/forum/viewtopic.php?t=265
Please post your hardware specs, other relevant info, and IO Meter results. Maybe this could get stickied? Or ignored if no one cares :)
Here's my info:
Stock NV
4 x Seagate ST3250823AS 250gb Hard Disk in X-RAID
All journaling disabled
Fast writes on
Intel D805 2.66ghz dual core cpu
Intel D945GNTLKR motherboard with onboard Intel Gigabit NIC
2 gigs ram
Seagate ST3250824AS 250gb Hard Disk
Windows Vista x86 RC1 (if that makes a difference)
Dell PowerConnect 2708 Gigabit switch (no jumbo frames)
Cat 6 cabling
IO Meter Write: 19.321793 MBps
IO Meter Read: 26.803979 MBps
Here's my info:
Stock NV
Fast writes on
2 gigs ram
Cat 6 cabling
- gattungAspirantHello folks, I started with the old 600A and I've had an X6 after that.
I just picked up the latest Pro 6 and am transferring all my data using rsync from the X6 to the Pro 6 using a gigabit switch (which is connected to a 100Mb router for readyfront access).
Both devices say they have gigabit connections.
The best speed I am seeing is 3MB/s with jumbo frames enabled, 2.5MB/s with it disabled.
Think the X6 nic is just not having it?
I am under the impression that having the two ReadyNASisis on the gigabit switch should leave them unaffected by the 100Mb router but do correct me if I am wrong about that.
Thanks! - StephenBGuru - Experienced User
You are not wrong about that.gattung wrote: ...I am under the impression that having the two ReadyNASisis on the gigabit switch should leave them unaffected by the 100Mb router but do correct me if I am wrong about that...
I think your speed issues are related to the CPU requirements for rsync. - @gattung - RSYNC is a memory and CPU hog when doing large tasks. It's great for incrementals though.
mdgm has a great guide when migrating. I believe he has a link in his signature. NFS is much faster for the initial transfer then you can switch to RSYNC for incrementals.
Just to make sure, did you upgrade your network cables when adding the gigabit switch? Should be at least CAT5e or higher. - gattungAspirant
Ah, Here I thought it was the most efficient, 4 days of rsync oh well.
Yep, I have 5e.
Thanks for the replies! - ipaul81AspirantReadyNas Ultra 2+
Connected to Apple Airport Extreme Router with Gigabit Ethernet
Laptop Connected to Rouer with WiFi 2.4GHZ 802.11N
Average read/write speed over wireless = 11mb/s - tiranorAspirant
tiranor wrote: Wow, nice difference.
With my Ultra4 with jumbo frames off, i have :
Single Caviar Green 3TB on NAS :
-40MB/s Read&Write with CIFS/SMB access
-55-90MB/s Read and 55MB/s Write with ftp access
Current config (2 Seagate 3TB added) :
-45MB/s Read&Write with CIFS/SMB access
-60-95MB/s Read and 60MB/s Write with ftp access
With the current config, IOMeter gives me 50MB/s Read and 55MB/s Write.
I don't know if jumbo frames are worth the investment on my Ultra4 (I would need to buy at least a compatible NIC on my computer and a third GS105 switch, my router is said to support only 2k jumbo frames). FYI, iperf gives me a constant 110MB/s between my computer and my NAS.
I just installed a 2GB Corsair RAM module, I now get :
-60MB/s Read and 48MB/s Write with CIFS/SMB access
-59MB/s Read and 57MB/s Write with IOMeter. - AllWinAspirantThe link on how to set up IOMeter seems to be dead, so i'll post ATTO disk benchmark result.
ReadyNAS Duo v2, SMB/CIFS, x2 SAMSUNG HD642JJ in Raid 1, Cat5E cables, Netgear WNDR3700v2 router and Windows 7 machine with integrated Realtek Gigabit NIC.
EDIT. Same test just with single Samsung HD204UI hard drive:
- AllWinAspirant
ipaul81 wrote: ReadyNas Ultra 2+
I'm not trying to be rude, but you're testing capabilities of your (Apple Airport EXtreme) router and not Netgear ReadyNAS, iPaul81. Even my 4 years old NAS was able to provide such speeds. Over the LAN you would get much better/adequate results. - tiranorAspirantAtto seems too optimistic, on my ultra4, it gives me 75MB/s Write and 100MB/s Read from 32k to 8192k.
- tiranorAspirantWell, due to a failed standard transfer over SMB (some files wouldn't be copied), i was in a hurry and retested transfer over FTP : 105-108MB/s constant read.
I don't know where was the bottleneck (my e-sata drive goes up to 105-110MB/s, the gigabit LAN with the NAS was rated constant 108-110MB/s) but I didn't care :D
