michelkenny
Sep 26, 2006Aspirant
Post your performance results
I thought it might be interesting to see what kind of performance everyone is getting with IO Meter so that we can compare what we're getting. So I thought we could all post our results in this thread for easy comparison.
You can run IO Meter by following the steps here: http://www.infrant.com/forum/viewtopic.php?t=265
Please post your hardware specs, other relevant info, and IO Meter results. Maybe this could get stickied? Or ignored if no one cares :)
Here's my info:
Stock NV
4 x Seagate ST3250823AS 250gb Hard Disk in X-RAID
All journaling disabled
Fast writes on
Intel D805 2.66ghz dual core cpu
Intel D945GNTLKR motherboard with onboard Intel Gigabit NIC
2 gigs ram
Seagate ST3250824AS 250gb Hard Disk
Windows Vista x86 RC1 (if that makes a difference)
Dell PowerConnect 2708 Gigabit switch (no jumbo frames)
Cat 6 cabling
IO Meter Write: 19.321793 MBps
IO Meter Read: 26.803979 MBps
Here's my info:
Stock NV
Fast writes on
2 gigs ram
Cat 6 cabling
- musicfanAspirant
PentiumD 3GHz 2GbRAM, LinkSys BEF SR41v4 Etherfast CableRouter with Cat5 cable
NV+ 1024Mb RAM, 4 disks X-RAID 500Gb Seagate ST3500630AS, Radiator 3.01c1-p6, UPS monitored, enable cache, disable journal, fast CIFS, Speed Auto-Negotiation, Smart disk check without problems.
Averages of several standard IOMeter protocol runs with and without jumbo frames enabled on NV+ (no difference) yielded...
MB/s Write=10.5
MB/s Read==9.0
Direct-connect:
Jumbo off, enable cache, disable journaling, CIFS writes, on UPS. Run both standard and with the maximum disk size quadrupled to 8192000 sectors with only a small difference.
MB/s Write 22
MB/s Read 44
musicfan wrote:
Does this diagnose the venerable LinkSys BEF SR41v4 Etherfast CableRouter 10/100 switch as the speed limiter or bottleneck? Thank you.
brendan replied:
Yes. It's not a deficiency of that particular switch, it's just that a 100 megabit switch can only move data at up to 100 megabits, which is what the original numbers were showing. If you want to get closer to the direct connect speeds, you need a 1000 megabit (aka gigabit) switch instead.
Pardons for that not being exact but I edited out the duplicate gear talk. The story is that after the above testing, I bought an SMC GS8 Gigabit switch and plugged the NV+ and computer (Intel Pro 1000 switch) into the GS8 with Cat5e and re-ran as before (no jumbo frames).
write 19 MB/s
read 33 MB/s
It's not as good as some but far better than before getting the Gigabit switch. I don't understand why the direct was a little better before but am not going to sweat that. Thanks brendan and everyone.
musicfan - lowfiAspirantIm on wireless N right now. Copying some m4v files to my NV+
Doing around 10 or 11MB/s for writes. Reads are around 15 or so.
I use a mac pro & airport extreme N (fast ethernet). All on AFP.
I had some pictures but i cant post them because of spam prevention :( - bhoarAspirant
lowfi wrote: Im on wireless N right now. Copying some m4v files to my NV+
I wouldn't expect any better numbers over wireless N.
-brendan - yoh-dahGuide
bhoar wrote: lowfi wrote: Im on wireless N right now. Copying some m4v files to my NV+
-brendan
Agree. I think these numbers are quite good for wireless. - lowfiAspirantI wasnt expecting more :)
I also plugged it directly in my mac pro and was getting around 23MB/s for writes and 45MB/s for reads. Think ill pick up a gbit switch or something and use the wireless solely for notebooks/appletv. - yoh-dahGuide
lowfi wrote: I wasnt expecting more :)
Maybe you can share your network recipe with other Mac users 8) - dminches1AspirantI followed all the instructions but I am get an error "Worker 1" on "JJG" cannot set specification NV (the name of my test file). The largest request or reply size (262144 bytes) may be too large.
Any idea what I am doing wrong? - dminches1AspirantOk. I got it working but the results are not pretty.
System:
Pentium 4 (3.2 GHz); 3 GB Ram; XP Pro
Intel PRO/1000 CT (jumbo frames disabled; link speed - auto detect)
Netgear GS608 switch
ReadyNas NV running RAIDiator 4.00b9-p1-T1 [1.00a037] in XRAID; 1 GB RAM
4x Samsung 500GB ; 75% filled
Disk write cache: ENABLED
Journaling: ALL DISABLED
Fast CIFS Writes: ON
I am getting around 10 MB/s on both reads and writes. This can't be the fastest speed I can get.
What should I change to improve the speed? I was wondering if my NIC card is the bottleneck. I can't see the switch being an issue since it is a gigabit switch. I am assuming I don't need to set anything on it since the NV reports 1000Mbit / full duplex.
Can someone give me a couple suggestions? - phrozenAspirantI ran the bench from:
http://www.infrant.com/download/iometer.icf
System:
Dell Poweredge 400sc
Pentium 4 (2.8 GHz); 1.5 GB Ram; XP Pro
Intel PRO/1000 MT (jumbo frames enabled; link speed - auto detect; all offload options enabled)
Netgear GS105 switch
ReadyNas NV running RAIDiator™ v3.01c1-p6 in XRAID; 256 MB RAM
4x Seagate ST3750640AS 698 GB ; 93% filled
1 Seq Read 256K: 16.411689 MBps
1 Seq Write 256K: 8.280536 MBps
Boo...
:cry: - PhiWi1AspirantHardware:
Some Core2Duo Notebook by LG with Broadcom Gig-E NIC
Netgear WNR854T DSL/WLAN/GIG-E Router
ReadyNas NV+
Jumbo Frames: ON
Virus Scanner: ON
Result:
Read: 30.40MB/s
