jmarczeski
Dec 01, 2016Guide
Power button and loss of connectivity
Recently have a ReadNAS 2120V2 Firmware 6.6.0 Computers Connected Win10 pro Nas seems to be dropping the connection to the network from time to time. The ethernet cards are set up as a bonded ...
Jan 27, 2017Guru - Experienced User
Do you have a backup? If not, can you make one now?
jmarczeski
Jan 27, 2017Guide
I back up everynight
- StephenBJan 27, 2017Guru - Experienced User
Great. The method of last resort is to do a factory reset and restore the data from your backup.
You might try over-installing (manually installing the same firmware you are running now) and see if the NICs come back and/or the power button starts responding.
