ahkjeldsen
May 04, 2015Aspirant
Power went out during defrag, no space left
Hi guys.
I have a ReadyNas RN104 with 2 x 4 TB drives (WD Red) running in raid.
I'm using the scheduler to automate defrag, scrub and balance. During the defrag the power went out and when it came back on, the defrag process was stopped. Before the drag I had about 1TB of space left, now after it has booted up again it said I had 132kb. I tried to do a disk balance which increased the free disk space to about 2GB.
I've SSH'ing into the NAS and tried to figure out where the space went, but I haven't been able to figure it out.
I've experienced something like this before, but that was due to the snapshotting not working properly and keeping old snapshots even though they should have been deleted. I've disabled snapshotting for all shares and deleted all old snapshot files, so it's not the same problem again.
Any help would be greatly appreciated :)
/# du -sh /
du: cannot access `/proc/8090/task/8090/fd/4': No such file or directory
du: cannot access `/proc/8090/task/8090/fdinfo/4': No such file or directory
du: cannot access `/proc/8090/fd/4': No such file or directory
du: cannot access `/proc/8090/fdinfo/4': No such file or directory
2.8T /
/# df -H
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 959M 2.9G 25% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 959M 2.9G 25% /
tmpfs 248M 0 248M 0% /dev/shm
tmpfs 248M 564K 248M 1% /run
tmpfs 248M 0 248M 0% /sys/fs/cgroup
tmpfs 248M 0 248M 0% /media
/dev/md127 3.7T 3.7T 2.1G 100% /data
/dev/md127 3.7T 3.7T 2.1G 100% /apps
/dev/md127 3.7T 3.7T 2.1G 100% /home
/# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
rootfs 65536 19181 46355 30% /
tmpfs 63410 273 63137 1% /dev
/dev/md0 65536 19181 46355 30% /
tmpfs 63410 1 63409 1% /dev/shm
tmpfs 63410 398 63012 1% /run
tmpfs 63410 4 63406 1% /sys/fs/cgroup
tmpfs 63410 1 63409 1% /media
/dev/md127 0 0 0 - /data
/dev/md127 0 0 0 - /apps
/dev/md127 0 0 0 - /home
/# dumpe2fs /dev/md127
dumpe2fs 1.42.10 (18-May-2014)
dumpe2fs: Bad magic number in super-block while trying to open /dev/md127
Couldn't find valid filesystem superblock.
/# fdisk -l
Disk /dev/mtdblock0: 1 MB, 1572864 bytes
255 heads, 63 sectors/track, 0 cylinders, total 3072 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0xf7ff1c18
Disk /dev/mtdblock0 doesn't contain a valid partition table
Disk /dev/mtdblock1: 0 MB, 131072 bytes
255 heads, 63 sectors/track, 0 cylinders, total 256 sectors
Disk identifier: 0x322e3535
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 6 MB, 6291456 bytes
255 heads, 63 sectors/track, 0 cylinders, total 12288 sectors
Disk identifier: 0xe1a0f004
Disk /dev/mtdblock2 doesn't contain a valid partition table
Disk /dev/mtdblock3: 4 MB, 4194304 bytes
255 heads, 63 sectors/track, 0 cylinders, total 8192 sectors
Disk identifier: 0x6e907a39
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/mtdblock4: 121 MB, 121634816 bytes
255 heads, 63 sectors/track, 14 cylinders, total 237568 sectors
Disk identifier: 0x00000000
Disk /dev/mtdblock4 doesn't contain a valid partition table
WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sda: 4000.8 GB, 4000787030016 bytes
256 heads, 63 sectors/track, 484501 cylinders, total 7814037168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 4294967295 2147483647+ ee GPT
Partition 1 does not start on physical sector boundary.
WARNING: GPT (GUID Partition Table) detected on '/dev/sdb'! The util fdisk doesn't support GPT. Use GNU Parted.
Disk /dev/sdb: 4000.8 GB, 4000787030016 bytes
/dev/sdb1 1 4294967295 2147483647+ ee GPT
Disk /dev/md0: 4292 MB, 4292804608 bytes
2 heads, 4 sectors/track, 1048048 cylinders, total 8384384 sectors
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1: 536 MB, 536543232 bytes
2 heads, 4 sectors/track, 130992 cylinders, total 1047936 sectors
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md127: 3995.8 GB, 3995818655744 bytes
2 heads, 4 sectors/track, 975541664 cylinders, total 7804333312 sectors
Disk /dev/md127 doesn't contain a valid partition table
- mdgm-ntgrNETGEAR Employee Retireddumpe2fs is for EXT file systems not BTRFS.
What is the output of
# btrfs fi show
# btrfs fi df /data
Do you have a backup? - ahkjeldsenAspirant
/# btrfs fi show
Label: '0e349638:data' uuid: 5b252353-262d-4dca-b468-4c417bb55dce
Total devices 1 FS bytes used 3.62TiB
devid 1 size 3.63TiB used 3.63TiB path /dev/md127
Btrfs v3.17.3/# btrfs fi df /data
Data, single: total=3.63TiB, used=3.62TiB
System, DUP: total=32.00MiB, used=456.00KiB
System, single: total=4.00MiB, used=0.00B
Metadata, DUP: total=2.00GiB, used=1.36GiB
No backup.. I can still access the data both via the web interface, SMB and http. - mdgm-ntgrNETGEAR Employee RetiredWhat is the output of the following?:
# btrfs subvolume list /data - ahkjeldsenAspirant
/# btrfs subvolume list /data
ID 256 gen 669576 top level 5 path home
ID 259 gen 669643 top level 5 path .apps
ID 260 gen 669576 top level 5 path .vault
ID 266 gen 669576 top level 5 path Backup
ID 267 gen 669576 top level 5 path ._share
ID 268 gen 669566 top level 5 path .timemachine
ID 418 gen 669576 top level 5 path .purge
ID 419 gen 669576 top level 256 path home/Mathilde
ID 424 gen 669576 top level 256 path home/Andreas
ID 431 gen 669644 top level 5 path Transmission
ID 460 gen 669639 top level 5 path Main
ID 732 gen 669576 top level 5 path readydrop
ID 1001 gen 669576 top level 256 path home/WDTV
ID 1016 gen 669576 top level 256 path home/ahkjeldsen
ID 4560 gen 669576 top level 5 path WWW
ID 4561 gen 669576 top level 4560 path WWW/.snapshots
ID 4562 gen 669576 top level 5 path www
ID 4563 gen 669566 top level 4562 path www/.snapshots
ID 4564 gen 669576 top level 431 path Transmission/.snapshots - ahkjeldsenAspirantIt's doing a rescan right now, but that doesn't seem to help either :/
# du -csh /data/* - ahkjeldsenAspirant
/# du -csh /data/*
11M /data/Backup
38G /data/home
2.8T /data/Main
1.9M /data/readydrop
2.5M /data/Transmission
1.7M /data/www
0 /data/WWW
2.8T total - mdgm-ntgrNETGEAR Employee RetiredDo you use Time Machine?
- ahkjeldsenAspirantNo, I don't use any automatic backup at all.
- mdgm-ntgrNETGEAR Employee RetiredWhat's the output of the following?:
# du -csh /data
