ahkjeldsen
May 04, 2015Aspirant
Power went out during defrag, no space left
Hi guys. I have a ReadyNas RN104 with 2 x 4 TB drives (WD Red) running in raid. I'm using the scheduler to automate defrag, scrub and balance. During the defrag the power went out and when it came...
ahkjeldsen
May 08, 2015Aspirant
mdgm wrote: Just to be clear in my post above I suggested expanding the volume then trying a defrag again.
Ahh my bad, I need to read closer then.
I'll try by all means to avoid a factory reset, so when you say expanding the volume, that would be inserting a new blank 4TB WD Red disk, right?
When inserting a new disk and expanding, it would also have to resync the data, right? So the defrag should be run after the resync?
