Martin_Lewinsky
Jan 02, 2010Follower
Printing Pdf documents with HP Color LaserJet CP1515n
Hi I've just bought a new printer: HP Color LaserJet CP1515n installed it on the network (ReadyNASDuo). Printing from word etc. just works fine. But when I try to print Pdf nothing happens including ...
BadBrad
Aug 13, 2011Aspirant
I just wanted to let you know I had the same problem with my Duo (running 4.1.6) and my Canon i960. Changing settings in Adobe Acrobat Reader 10 to print as an image (instead) helped some, but the problem still did not go away. Like another poster mentioned, printing a word doc or text file before printing a second PDF often allowed the second PDF to print.
The real fix for me was as follows: On a lark, I uninstalled Adobe Acrobat Reader and installed Foxit instead as my PDF reader. Since installing Foxit, I have had no problems printing PDFs. It looks like Foxit printing interacts perfectly with the Duo while Adobe Acrobat does not.
- May 12, 2025Retired_Member
