rtpnc6's avatar
rtpnc6
Pro 2 Cyclic Noise
I just received my Pro 2 (2x2TB) unit and I am hearing a noise which sounds like the disk drives seeking every 15 secs when there is no access activity from any PC. The unit firmware is 4.2.19, the drives are Seagate Constellation ES ST32000644NS. There are no errors in the logs and everything on Frontview is green. The noise persists even if the network cable is disconnected from the unit. I can see the disk activity light flash when the noise happens. The disk lights below are solid green. Is this a normal sound/behavior? The unit seems to work properly in all aspects.
  • I would advise contacting the tech support and send in the system logs for review. it could be hard disk issue and need RMA.
  • The logs are clear and the SMART attributes are fine as well. No Reallocated sectors at all. It really sounds like the drives are resynching with each other on a periodic basis. I'll discuss with tech support, but I'm not sure what additional items should be examined.
    SMART Information for Disk 1
    Model: ST32000644NS
    Serial: 9WM5WLY3
    Firmware: SN12
    SMART Attribute
    Spin Up Time 0
    Start Stop Count 11
    Reallocated Sector Count 0
    Power On Hours 48
    Spin Retry Count 0
    Power Cycle Count 8
    Reported Uncorrect 0
    High Fly Writes 0
    Airflow Temperature Cel 26
    G-Sense Error Rate 0
    Power-Off Retract Count 5
    Load Cycle Count 11
    Temperature Celsius 26
    Current Pending Sector 0
    Offline Uncorrectable 0
    UDMA CRC Error Count 0
    ATA Error Count 0
    SMART Information for Disk 2
    Model: ST32000644NS
    Serial: 9WM5QYMQ
    Firmware: SN12
    SMART Attribute
    Spin Up Time 0
    Start Stop Count 11
    Power On Hours 49
    Spin Retry Count 0
    Power Cycle Count 8
    High Fly Writes 1
    Load Cycle Count 11
    ATA Error Count 0
ProSupport for Business
