coricidin12
Jul 25, 2012Aspirant
PRO 6 locking up
I have a pro 6 with a 9tb volume and a 6tb volume. About once a week, the whole drive drops off the network and can't be accessed through CIFS or the web admin interface. It doesn't turn off, the lig...
Jul 25, 2012Guru - Experienced User
You can do a ping in windows by opening a cmd box (enter "cmd" in the "search programs and folders" textbox). At that point you will see a window open up with a black background. Select it, then type "ping xxx.xxx.xxx.xxx" (xxx's are the NAS ip address) and then press enter. you should see four responses that say "Reply from xxx.xxx.xxx.xxx: bytes-=32 time<1ms TTL=64" There will be some other stuff also (statistics, etc).
