Dave_Ams
Mar 17, 2016Tutor
Pro 6: Managment Services is offline (RNOS 6.4.2)
All, I have seen this issue on other posts but no direct answer. My NAS has stopped responding, Both WebGUI and SSH no longer work. It might have happened after it filled up. Unfortunately n...
- Mar 18, 2016
There was a problem with the filesystem on the root volume, so I copied the contents off, formatted the root volume, copied the data back and fixed a few things with the root volume then booted it back to normal mode.
mdgm-ntgr
Mar 18, 2016NETGEAR Employee Retired
Looks like the system has now come back up fine. Please confirm.
Dave_Ams
Mar 18, 2016Tutor
Hi,
Yes it has! Many thanks for helping me out!.
What was the problem with the system?
David
- mdgm-ntgrMar 18, 2016NETGEAR Employee Retired
- Jun 11, 2022Retired_Member
