StephenB's avatar
PRO 6 poor read performance??
Just got a PRO 6, and started by installing a single Seagate ST31500341AS hard drive as XRAID2. (only spare disk I have at the moment, the real disks are on order). Performance settings are defaulted (write caching on, full data journalling disabled). SMART status is ok, and a read test with a disk diagnostic completed successfully. The PRO is running 4.2.17.
Then I downloaded the Iometer test script (the one Netgear published) and tried it.
I get about 75 megabytes of performance when writing, but only about 42 when reading. I confirmed this with drop-and-drag measurements.
I've tried both ethernet ports, testing with a different switch and with a different PC. Also tried a different ethernet cable. Network stats on the PRO are not showing any errors (and neither is my managed switch).
I am concerned that this might a hardware issue in the PRO, and am wondering if anyone else has seen this behavior?
ProSupport for Business
