dsm1212
Dec 01, 2015Apprentice
Pro 6 upgrade to 6.4.1
FWIW I updated from 6.2.4 to 6.4.1 and had a few minor issues: 1. wordpress was no longer working. I hadn't used it much so I uninstalled for now, but if I had been a big wordpress user I might h...
dsm1212
Dec 02, 2015Apprentice
CPU is 1622 and system fan is 907. CPU is 37c and system is 64c. This is no change for me. I think the cpu cooler is overdue for a cleaning. The system temp has always been high even though I can't feel it anywhere near that hot at any point inside or out. So far so good.
steve
BrianL2
Dec 02, 2015NETGEAR Employee Retired
Hi dsm1212,
Thanks for the feedback. Have you reinstalled the WordPress add-on? Get a fresh copy here.
Kind regards,
BrianL
NETGEAR Community Team
- AmosNZDec 03, 2015Aspirant
I upgraded my Pro6 from 6.4.0 to 6.4.1 and DVBLink TV Server stopped recognising the tuner. No doubt DVBlogic will update their driver in a new build, but just a word of caution for any others before upgrading.
- dsm1212Dec 03, 2015Apprentice
This morning I found the system was hung. No access to anything including ssh. Log shows it was a GPF. The crash happened 10 minutes after a quarterly drive rebalance job I had scheduled. I power cycled and it came back up.
steve
Dec 03 04:25:31 warehouse6 kernel: general protection fault: 0000 [#1] SMP
Dec 03 04:25:31 warehouse6 kernel: Modules linked in: nv6lcd(O) vpd(PO)
Dec 03 04:25:31 warehouse6 kernel: CPU: 1 PID: 14484 Comm: sleep Tainted: P O 4.1.13.x86_64.1 #1
Dec 03 04:25:31 warehouse6 kernel: Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS 080014 07/26/2010
Dec 03 04:25:31 warehouse6 kernel: task: ffff88024686a010 ti: ffff8801cc78c000 task.ti: ffff8801cc78c000
Dec 03 04:25:31 warehouse6 kernel: RIP: 0010:[<ffffffff8811f337>] [<ffffffff8811f337>] filp_close+0x17/0x80
Dec 03 04:25:31 warehouse6 kernel: RSP: 0018:ffff8801cc78fef8 EFLAGS: 00010282
Dec 03 04:25:31 warehouse6 kernel: RAX: ffff8801091c8940 RBX: 8f5c21baea331f00 RCX: ffff88002c0cf000
Dec 03 04:25:31 warehouse6 kernel: RDX: 0000000000000001 RSI: ffff880246f7a5c0 RDI: 8f5c21baea331f00
Dec 03 04:25:31 warehouse6 kernel: RBP: ffff8801cc78ff18 R08: 00007fbe2e7727a0 R09: 00007fbe2e98c700
Dec 03 04:25:31 warehouse6 kernel: R10: 00007fffc6c08620 R11: 0000000000000246 R12: 0000000000000001
Dec 03 04:25:31 warehouse6 kernel: R13: 00007fbe2e771c60 R14: 0000000000000000 R15: 0000000000000000
Dec 03 04:25:31 warehouse6 kernel: FS: 00007fbe2e98c700(0000) GS:ffff88024fc80000(0000) knlGS:0000000000000000
Dec 03 04:25:31 warehouse6 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
Dec 03 04:25:31 warehouse6 kernel: CR2: 00007fbe2e43fd20 CR3: 0000000173f0b000 CR4: 00000000000406e0
Dec 03 04:25:31 warehouse6 kernel: Stack:
Dec 03 04:25:31 warehouse6 kernel: ffff8801cc78ff58 ffff880246f7a5c0 0000000000000001 00007fbe2e771c60
Dec 03 04:25:31 warehouse6 kernel: ffff8801cc78ff38 ffffffff8813d9ef 00007fbe2e7712a0 0000000000000000
Dec 03 04:25:31 warehouse6 kernel: ffff8801cc78ff48 ffffffff8811f2ee 0000000000000000 ffffffff889b2017
Dec 03 04:25:31 warehouse6 kernel: Call Trace:
Dec 03 04:25:31 warehouse6 kernel: [<ffffffff8813d9ef>] __close_fd+0x6f/0x90
Dec 03 04:25:31 warehouse6 kernel: [<ffffffff8811f2ee>] SyS_close+0x1e/0x50
Dec 03 04:25:31 warehouse6 kernel: [<ffffffff889b2017>] system_call_fastpath+0x12/0x6a- smarDec 08, 2015Tutor
Since upgrading to 6.4.1 my nas seems to lose all connectivity every couple of days. Only way out is to hard reboot. After the last reboot a couple of days ago, I noticed that it has started balancing - and again lost all connectivity (no web admin, no ssh, no ping reply etc). The balancing is also taking quite some time (it is at 12% after about 24 hours). There is about 800Gb free on a Raid 5 set up (5 x 2Tb on ReadyNAS PRo), so hopefully sufficient free space for the balancing.
