reburns
Mar 01, 2024Aspirant
Pro Pioneeer suddenly racking up numerous ATA error counts on all drives (RNDP6000-V2)
Hello, my Pro Pioneer suddenly started issuing "Detected increasing ATA error count" messages. I first received one, removed the HDD to confirm the serial number, replaced the HDD (system now syncin...
Sandshark
Mar 01, 2024Sensei
Actually, all ReadyNAS are now considered "end of life", so no Netgear support is available beyond warranty.
ATA errors are tricky. They are the only SMART error that may not actually be the fault of the drive. One bad drive can even "contaminate" the SATA subsystem and cause ATA errors on other channels.
Removing each drive (with power off, once the sync has completed) and testing each with Seatools is your best next step.
reburns
Hello again -
Question: how bad is it for the drives if I fire up the Pro Pioneer again to compare file backup to my other NAS before I retire the unit? It is my hope to re-use the existing HDD's in a new NAS. The ATA error count reached 2000 on the drives today during the time it was on. Any meaningful data comparison and transfer will likely take a few hours and the sync will not have time to finish before pursuing that Seatools test.
I'm considering two 6-bay replacements based upon compatibility with my existing WD161KFGX and WD181KFGX drives, and price, and your opinions are welcomed!
Asustor AS6706T
QNAP TS-673A
- SandsharkMar 02, 2024Sensei
ATA errors themselves won't harm the drives. Of course, whatever is causing them could get worse and the NAS stop working. At the very least, whatever it is will likely slow things down.
