Conz
Oct 10, 2012Aspirant
Pro pioneer 2TB -> 3TB disks
Is it possible to online swap 2TB disks for 3TB disks (or 4TB :-)) yet ? I seem to recall having to factory default when swapping to larger disks, I'd need a 2nd NAS to be able to store all the data ...
mdgm-ntgr
Oct 10, 2012NETGEAR Employee Retired
No 4TB drives have been qualified at this time. Some users report success with these disks but NetGear can and will deny support if you run into issues using 4TB disks.
There are some 3TB disks on the list.
What disks were installed when you last did a factory default? Were all six 2TB disks installed or some other disk configuration?
What RAID configuration are you using e.g. X-RAID2 dual-redundancy?
