Conz
Oct 10, 2012Aspirant
Pro pioneer 2TB -> 3TB disks
Is it possible to online swap 2TB disks for 3TB disks (or 4TB :-)) yet ? I seem to recall having to factory default when swapping to larger disks, I'd need a 2nd NAS to be able to store all the data ...
Conz
6 times 2TB RE4-GP WD's at the last reset.
They were all installed at once, in xraid 2 with single redundancy.
I figured the 4tb disks are not on the list yet, they're not generally available here either I think, but thankfully there is no urgency to expand my nas yet
[edit]
mmm i just noticed the release notes:
[edit]
Volume expansion will not work beyond 16 TB. To support 16 TB or greater, you’ll have to factory default with that capacity in place.
