Conz
Oct 10, 2012Aspirant
Pro pioneer 2TB -> 3TB disks
Is it possible to online swap 2TB disks for 3TB disks (or 4TB :-)) yet ? I seem to recall having to factory default when swapping to larger disks, I'd need a 2nd NAS to be able to store all the data ...
mdgm-ntgr
Oct 21, 2012NETGEAR Employee Retired
So you had all six disks installed when you did the factory default? You should be able to replace the disks one by one to expand the volume. Personally though with that much data I'd feel much more comfortable using dual-redundancy. However to use dual-redundancy you'd have to backup your data and do a factory default (wipes all data, settings, everything).
