Conz
Oct 10, 2012Aspirant
Pro pioneer 2TB -> 3TB disks
Is it possible to online swap 2TB disks for 3TB disks (or 4TB :-)) yet ? I seem to recall having to factory default when swapping to larger disks, I'd need a 2nd NAS to be able to store all the data ...
MrCyberdude
Nov 09, 2012Tutor
I suggest you REALLY rethink about moving to Dual redundancy and do it now while you have the room and hopefully the redundancy for the rebuild.
Read this, Why Raid5(Single Redundancy) is not enough and why Raid6(Dual Redundancy) is better. Raid5 Failures HDD MTBF XRaid2 Raid6 Dual Redundancy viewtopic.php?f=11&t=42989
I have had a failed raid5 rebuild and it was not pretty. I had to individually extract the raid5 partitions from the hdd's and rebuild with software. you can imagine the time taken.
