rrg
Dec 21, 2011Aspirant
Pro Pioneer NFS performance problem
For as long as I've had it I've been using NFS on the Pro Pioneer to serve video files to various media players in my house (a Dune HD Base 3.0, a TViX 4100, a Popcorn Hour A-100) with excellent resul...
rrg
Jan 29, 2012Aspirant
russrtw wrote: Perhaps I need to check the 4200's and 3100's that I have connected to GS724TR switches via NFS to Xen hosts. Good to see this post.
Was this specific to the GS724TR? In other words, were you able to try a different managed switch with flow control disabled as well? What firmware were you running, and did they advise you upgrade it? (There have been quite a few updates to the GS724TR software).
It's been my understanding for years that flow control produces more undesirable results on average.
I didn't have another managed switch to try so I don't know how another might have behaved.
They advised me to upgrade to the latest switch firmware (which I was already on anyway) before turning on flow control.
I hadn't deliberately turned it off prior to this, so "off" was likely the default setting. So yes, it did surprise me when they suggested the change.
