clobberator
Feb 23, 2014Aspirant
Pro Pioneer Shuts Down, won't stay down.
I have a ReadyNAS Pro Pioneer, purchased some time ago, probably 5 years? Anyways, aside from disk failures, it's been trouble free. Until recently - I try to power down the unit, but after a few ...
berkut1
May 24, 2014Tutor
clobberator wrote: Fixed this issue by swapping in a new power supply.
I am having the same problem with my NAS Pioneer Pro failing to stay shutdown via either the web page or front panel.
I will go ahead and replace the power supply and cross my fingers that will do the trick.
Thanks for posting your problem & solution.
