nyCecilia
Apr 09, 2020Aspirant
Pro Pioneer suddenly says it's overheating?
Hi all, I've been running my Pro Pioneer for over a decade now, and it's been on the last known firmware (4.2.31) for a couple of years with no problem. Suddenly last night I get a notice that Sens...
- Apr 09, 2020
Could be a build-up of dust, pet hair, etc. on/near the sensor or in the vent holes (esp. of the door). If you smoke near the NAS, it can be far worse, as the tar acts as glue. If the location of the NAS is near the floor, especially if not carpeted, that can also lead to more debris build-up (esp. pet hair).
If you have any slots without drives or caddies, fill them with caddies. The airflow is designed to include that resistance. But that likely would not be the cause of a sudden change.
The only real option for debris build-up is to open it up and see, using compressed air (aerosol can type is fine) to remove anything you find. If there is tar residue, you may need 90% alcohol and a q-tip, but use care and insure everything is dry before powering on. If you use air to clean the fan, don't let it free-wheel. That can damage the bearings. Use something to keep it from rotating while you spray.
Lastly, check your air conditioning if you are somewhere that currently has warm weather. I had an "overheat problem" and it turned out my A/C was cutting out mid-day when I was at work (I found out a few days later when it quit entirely). But, that would likely affect drive temperatures, too.
If you do find a debris build-up, doing a compressed air clean-out periodically without disassembly can help prevent future problems. But once you have a problem, you almost laways need a thorough cleaning, which requires taking off the covers. One of my spring cleaning trasks is to take every computer, NAS, etc. outside and dust them out with compressed air. But I do have an air compressor.
Sandshark
Apr 09, 2020Sensei
nyCecilia
Hi Sandshark, and thanks so much. This is kind of one of my suspicions...I have a little "under the stairs server room" that is cut off to pets, raised off the floor, I don't smoke, and I'm in the bay area where it rarely goes above 70 F (I don't have A/C), but for the last week there has been construction near my apartment and I suspect that may be related. I'm in the process of emptying the little closet out of boxes, thinking that all that cardboard certainly can't help the situation.
I did open it up this morning and there was a ton of junk in there so I blew out as much as I could with canned air and right now it's been on for about an hour and Temp Sys (sensor 1) seems to be holding at 60C which still seems hot. CPU is still at 34C and all the drives in a similar range.
I do have one open bay but the caddy is in there and has been all along. Do you think it would be beneficial to put a drive in it? I bought a couple of drives for replacing the two oldest ones when the prices went down recently, but I've been saving to do that, still the two oldest aren't *very* old yet.
I didn't think about alcohol cleaning...so that I don't get it too wrong, are there any particular parts that I should look for to clean with alcohol? I do have 90% from a previous project, although it's likely on the old side.
Thank you so much for your quick response. I am hopeful to keep my server running, at least until there are more ReadyNas ready in the stores!
Cecilia
- nyCeciliaApr 09, 2020Aspirant
Ugh, I wonder if I accidentally harmed the SYS fan...it was spinning fine last night, but today it seems to be moving pretty slowly despite the 60c Sys temp.
- StephenBApr 09, 2020Guru - Experienced User
Do you recall what it was before the overheating incident?
Unfortunately, no. It's been months since I've even had to think about it. Bad on me, but I just got busy. Maybe 60c is normal?
