clobberator
Feb 04, 2013Aspirant
Pro Pioneer turns itself on after shutdown
I have a Pro Pioneer running the latest firmware (4.2.22). Recently, about 2 months ago it started behaving strangely. I have it scheduled to power on (1900h)/off (2330h) at certain times of the d...
CaseyH
Feb 05, 2013NETGEAR Expert
Cloberator,
First thing I would try is removing the power on/off settings and then try shutting it down. If that does not work, do an OS Re-Install (see link below). If this does not fix the issue, you will need to call in and have one of our tech-support login and check the OS for files that maybe keeping the unit from shutting down properly.
