Royan
Jan 09, 2017Aspirant
Pro2 6.1.7 -> 6.6.0
Hi. I have an old Pro2 box running OS6 6.1.7 (Yes, I know I havent updated in a looong time) I was thinking of updating it to 6.6.0, but I was wondering about the release notes. They state t...
- Jan 09, 2017
All those systems have ARM processors, I haven't seen any constraints like that for any x86 system.
So I think you can upgrade straight to 6.6.1. However, I do suggest backing up your data first, especially since your volume is so old.
Jan 09, 2017Guru - Experienced User
- RoyanJan 09, 2017Aspirant
Thank you.
I will try to update to 6.6.1 directly (one of these days TM :) ).
All my important files are already synced daily to Amazon S3, but I will definitely make a backup of all files first.
brgds
Royan
