davidr1
Sep 30, 2015Luminary
Pro2 OS6 WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!
Hi, Pro2, OS6, Ubuntu Not sure why (I may have disabled /re-enabled SSH?) but I received this warning today: david@ubuntu-140402C:~$ ssh root@192.168.1.8 @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@...
- Oct 01, 2015
In the UI you must have had private home shares enabled. When you login via SMB for the first time as a user the home share for it is created.
mdgm-ntgr
Sep 30, 2015NETGEAR Employee Retired
If you have a dynamic I.P. it's also possible it's got an I.P. you've previously SSH'd into to a different device.
This issue can be encountered with any device you want to SSH into.
I would typically use the latter of those two commands you mentioned.
This warning is more important when logging in to remote sites. It's a security precaution to provide warning of a possible man-in-the-middle attack.
- davidr1Oct 01, 2015Luminary
Thanks mgdm.
ssh-keygen -R <ip.of.nas>
My password resulted in:
Permission denied, please try again.
nut the password still works in the browser.
I tried using 'password' as a long shot with the same result.
Any ideas please?
Best regards,
David
- mdgm-ntgrOct 01, 2015NETGEAR Employee Retired
Try changing your password in the web admin interface of the NAS.
Thanks for helping, mgdm.
OK, password accepted using ssh. Then ....
david@ubuntu-140402C:~$ ssh root@<ip>
david@192.168.1.8's password:
Creating directory '/home/david'.Not sure why it did this?
Looking at home:
root@NASPro:/# cd home
root@NASPro:/home# ls -al
total 16
drwxr-xr-x 1 admin admin 10 Sep 25 13:15 .
drwxr-xr-x 1 root root 198 Sep 25 13:34 ..
drwx------ 1 david users 0 Oct 1 13:13 davidOK but rmdir david won't work as I can see I don't have full permission.
root@NASPro:/home# rmdir david
rmdir: failed to remove `david': Operation not permittedI am confused why directory david just created is poputated:
root@NASPro:/home# cd david
root@NASPro:/home/david# ls -al
total 0
drwx------ 1 david users 0 Oct 1 13:13 .
drwxr-xr-x 1 admin admin 10 Sep 25 13:15 ..Can I get rid of home/david that was just created in and if so how? 'david' is my username, group 'users'
Many thanks,
David
