davidr1
Sep 30, 2015Luminary
Pro2 OS6 WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED!
Hi, Pro2, OS6, Ubuntu Not sure why (I may have disabled /re-enabled SSH?) but I received this warning today: david@ubuntu-140402C:~$ ssh root@192.168.1.8 @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@...
- Oct 01, 2015
In the UI you must have had private home shares enabled. When you login via SMB for the first time as a user the home share for it is created.
davidr1
Oct 01, 2015Luminary
Thanks for helping, mgdm.
OK, password accepted using ssh. Then ....
david@ubuntu-140402C:~$ ssh root@<ip>
david@192.168.1.8's password:
Creating directory '/home/david'.
Not sure why it did this?
Looking at home:
root@NASPro:/# cd home
root@NASPro:/home# ls -al
total 16
drwxr-xr-x 1 admin admin 10 Sep 25 13:15 .
drwxr-xr-x 1 root root 198 Sep 25 13:34 ..
drwx------ 1 david users 0 Oct 1 13:13 david
OK but rmdir david won't work as I can see I don't have full permission.
root@NASPro:/home# rmdir david
rmdir: failed to remove `david': Operation not permitted
I am confused why directory david just created is poputated:
root@NASPro:/home# cd david
root@NASPro:/home/david# ls -al
total 0
drwx------ 1 david users 0 Oct 1 13:13 .
drwxr-xr-x 1 admin admin 10 Sep 25 13:15 ..
Can I get rid of home/david that was just created in and if so how? 'david' is my username, group 'users'
Many thanks,
David
mdgm-ntgr
Oct 01, 2015NETGEAR Employee Retired
- davidr1Oct 01, 2015Luminary
It looks like I did.
The shares I use were created in /data/. As this has just happened, how can I delete it?
thanks,David
