afro
Dec 19, 2010Aspirant
Problem - Readynas pro rndp600e + netgear GS-Serie Switch
Recently, I've been in touch with Netgear's Customer support (NETGEAR Support case #14006630) about this problem : A PC, windows 7, linked to the NAS (5x1.5to) through a GS-605 Gigabit switch. As s...
afro
Dec 24, 2010Aspirant
thanks for this very complete answer. I've tried to disable the flow control setting but no effect, transfers are either slow, either stop.
Below, you can see, for the same test files 10x300mo, what's happening. Reading from the pro is perfect, writing to it is just messy.
As for reallocated sectors, most of the hds are at zero, one around 3-4 and the worst being at 20. Most of them are from this year.
I"ll try to reinstall the network card and see if it can improve things. I don't know if this will reset all windows setting concerning network transmissions.
