reburns
Dec 25, 2021Aspirant
ReadyNAS Pro Pioneer drive not adding (RNDP600E)
Hello & happy summery winter Saturday! Question on Pro Pioneer 6.9.6
I have hot removed a 16TB WD Red Pro HDD in slot #2 and added a brand new 18TB WD181KFGX, however the volume is not rebuilding using the new HDD.
Have I done something out of order? Should I remove the new HDD and connect via SATA adapter to a computer and look for any factory partitions that need removing? I never needed to do that before with a brank new WD HDD...
There are errors in the log files for the new disk
Dec 25 09:55:22 Ascent-Pioneer kernel: ata2.00: failed command: SMART Dec 25 09:55:22 Ascent-Pioneer kernel: ata2.00: cmd b0/d0:01:00:4f:c2/00:00:00:00:00/00 tag 5 pio 512 in res 53/10:00:00:00:00/00:00:00:00:00/00 Emask 0x81 (invalid argument)
Dec 25 09:53:09 Ascent-Pioneer kernel: ata2.00: status: { DRDY ERR }
Dec 25 09:53:09 Ascent-Pioneer kernel: ata2.00: error: { IDNF }
Dec 25 09:53:09 Ascent-Pioneer kernel: do_marvell_9170_recover: ignoring PCI device (8086:2821) at PCI#0
Dec 25 09:53:09 Ascent-Pioneer kernel: ata2.00: failed to enable AA (error_mask=0x1)I suggest testing the disk in a PC with WDC's dashboard program.
BTW, you shouldn't post the log zip publicly - there is privacy leakage when you do that. I've redacted your link.
- reburnsAspirant
Thank you times two Stephen!
Q: Can I re-insert the old HDD back into that slot 2 and get redundency back in the meantime??
