tradtke
Jun 19, 2017Aspirant
Problem After upgrade to 6.73. TFTP_REQ
We have a 4220 ReadyNas whtat we upgraded from 6.5.1 to 6.73. After the upgrade the RAIDr shows status as TFTP_REQ. We tried the USB recovery Tried the USB recovery a 2nd time with 6.74 (according...
Jun 19, 2017Guru - Experienced User
Try disconnecting everything from the USB ports and see if that will reboot.
tradtke
After the USB recovery the system shuts down as is supposed to according to the directions. We then pull the USB drive so no USB is plugged into the NAS, power on the unit. It boots but ultimatly settles into the RAIDr showing the status: TFTP_REQ
- HopchenJun 19, 2017Prodigy
Hi,
Can you even cycle through the boot menu? Will it do anything? Is it possible to boot into Tech Support Mode? If so, then probably let Support have a look at it.
https://kb.netgear.com/24869/How-do-I-access-the-boot-menu-on-my-ReadyNAS-3220-4220
- tradtkeJun 19, 2017Aspirant
Good Question. Yes, we defiinlty can cycle thru the boot menu.
We Can even ping the default address 192.168.168.168 and telnet to the unit (although we dont have the UN/PW as NetGear says they dont give that out)
Nothing plugged into any of the USB ports....
- StephenBJun 19, 2017Guru - Experienced User
No UPS that uses USB either?
