fastfwd
Jan 15, 2017Virtuoso
Problem getting Intel microcode to load early on my Frankenstein NAS
So... After running multiple legacy ReadyNAS boxes on OS4 for 5+ years, I've decided to upgrade to OS6. I wish I knew who made the decision to include software support for legacy devices in OS6 (and...
- Jan 17, 2017
Ok, I've answered my own question. It is NOT necessary to lzma-compress the initramfs file on the boot flash.
As described in my previous post, I created a cpio archive just like the one inside initrd.gz, except that it also contains the /kernel/x86/microcode/GenuineIntel.bin file with my CPU's microcode update. Copied it to the boot flash without lzma-compressing it first (called it "initrduc"), edited SYSLINUX.CFG to load it along with my new kernel ("k4-1-30.uc") as a boot-menu option, and boom:
root@NAS3:~# dmesg | head [ 0.000000] microcode: CPU0 microcode updated early to revision 0xd0, date = 2010-09-30 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.1.30.x86_64.1 (root@NAS3) (gcc version 4.9.2 (Debian 4.9.2-10) ) #2 SMP Tue Jan 17 01:33:26 PST 2017 [ 0.000000] Command line: initrd=initrduc reason=normal BOOT_IMAGE=k4-1-30.uc [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] Disabled fast string operations [ 0.000000] e820: BIOS-provided physical RAM map:
Now my NAS not only has a CPU updated to the latest microcode, it's also running a kernel built specifically for its hardware (Core2 Duo CPU, Yukon2 Ethernet chip) and with a few other optimizations for that hardware.
If everything's still running fine a few days from now, I'll make this kernel/initramfs combo the default, and make the original combo a boot-menu option. Then I'll run through the process again for my main NAS, and maybe also for the Atom D525 in my little Ultra 2 Plus.
mdgm-ntgr
Jan 16, 2017NETGEAR Employee Retired
1. Modifying that would require building your own /init for it as well, I think
2. I think it would be unlikely that that would happen. The number of users that would benefit would be quite small. Unsupported unit for OS6 with an unsupported CPU upgrade
- fastfwdJan 16, 2017Virtuoso
Thanks, mdgm.
Your comment helped me to find what I think is a way to do what I want, and it's actually super-easy. I'll try it after lunch and post an update here.
And, yeah, I agree that it's unlikely that OS6 will include kernel features not only for products no longer supported by Netgear, but also for products that were NEVER supported by Netgear... But I made the suggestion anyway, under the basic principle of "It can't hurt to ask".
