torsnook
Feb 06, 2014Aspirant
Problem with Firmware upgrade
Hi I have just upgraded my ReadyNAS Duo to 4.1.13 firmware It all appears to have worked except I can't access the front panel. I can access the drives and the normal add ons seem to work I just can...
data_burger
May 06, 2014Aspirant
Hi,
Same problem here. I upgraded to the latest version of firmware 4.1.13 and thankfully I had some addons installed (ssh access being the most useful). I noticed that the front panel isn't starting up properly and drilled this down to a missing apache2ctl that is being called by the apache2 init.d startup script. I also have git installed.
How can I install the required apache version which seems to be incorrectly installed? I think my warranty period might be out of date as well.
Thanks.
Bartek
Thanks.
Bartek
